Audio-Techica PRO 70 Mic
    The krivo can mount on any guitar as long as there is enough string clearance. It uses putty to mount so the sound hole and internal bracing aren't a factor.
    the closest you can get to an acoustic tone without getting feedback in a cafe is the schertler basik in my opinion
    , if you place it jsut right behind the upper moustache near the bridge , it sounds decent... not fully acoustic, but certainly closer than a stimer....
    i also own the pro 70 mic which i mainly use in concert halls where there's a soundman
    i used this setup the other day at a loud bar and was able to crank it pretty loud without any feedback: viewtopic.php?f=9&t=8084
    i was on a wrembel gitane through a roland ac-60
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006311 / 1.062645]
