do D hole guitars have wider necks?
hi guys
If you know sth about subject, please let me know.
  • seeirwinseeirwin ✭✭✭ AJL J'attendrai | AJL Orchestra
    A 12 fret D hole typically has a wider neck than the 14 fret (D or oval hole) guitars. AJL guitars are built this way:
    12 fret D hole neck: 48 mm wide at the nut
    14 fret D or oval hole: 45 mm wide at the nut
  • rafapakrafapak ✭✭
    edited December 2010 Posts: 221
    thanks for reply
    my budget is 1000 $ therefore I can forget about AJL guitars
    I discovered that Gitane DG 320 has got 14 frets and neck width is 1 3/4
    I only mentioned AJL because I think he uses a fairly standard dimension.
    My '92 Dupont d-hole has a neck that's the same width as a 14-fret, but I have never seen another one quite like it. I'm surprised that more makers haven't explored that idea.
    Gitane D500 has a wider neck. 1-7/8" vs the 1-3/4" of the DG320. It's not quite as wide as a classical guitar (2"), but it isn't far off. That should be in your budget too
  • JazzDawgJazzDawg New
    edited January 2011 Posts: 264
    Yes.
  • pmh425pmh425 Middle Island, NY✭✭✭✭
    My Dell Arte Sweet Chorus (12 Fret D) is approximately 45mm
    -Peter
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.014195 Seconds Memory Usage: 2.376961 Megabytes
