regular tension or high tension nylon strings
hi guys
which of those could be better for cigano gj 10, regular tension or high tension nylon strings
    If your going to try putting nylon strings on a steel-string guitar, use as high a tension as you can buy. You'll need all the tension you can get to keep the floeating bridge pressing into the top. There's a reason that classical guitars have a fixed bridge. Even Selmer used a fixed bridge on the nylon string d-holes (the Concert model).
  • rafapakrafapak ✭✭
    thanks!
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005797 / 1.052368]
