3 note picking pattern
edited June 2013 in Gypsy Picking Posts: 8
Hi All,
Exercise 8.2 in the Horowitz book leaves me perplexed.
It's basically 3 consecutive descending notes on high e (could be any pattern) followed by same thing on b string. The right hand picking pattern is D U D and D U D.
My question is: I have no trouble completing the first 3 notes. But then once that last downstroke is completed, from there to the first downstroke on the b string seems like such an unnatural leap/jump. It's sort of the opposite of the standard reststroke, in that once it's completed, the pick is not resting anywhere.
And I had though the arpeggios were the main difficulty... shoo wee!
Any thoughts on how to practice this?
TR
    Slowly and with a mind to staying relaxed. All unfamiliar things seem hard until they become familiar.
    What helps me with the whole 'starting every new string with a down stroke' thing is imagining my pick "bouncing" up and off of the string when doing a down stroke before switching strings to another down stroke.
    Anthony
    Thanks Anthon, that helps.
    I'm thinking maybe not following through all the way when I do the downstroke on the last note on the high e string helps before I do the first downstroke on the b string. But I don't know if the picking/tone police would be happy with that.
    I think that there was a thread sometime ago where they were saying that Stochelo does not follow all the way thru on downstrokes when he is doing repeated downstrokes going back up the strings. I think that he calls them 'normal' strokes rather than 'rest' strokes or something like that.
    jonathanmaness
    Bones, that's very helpful! Thanks for pointing that out. If that's the case, then I can see now how it wouldn't feel impossible, I'm seeing improvement from doing that already. It makes a lot of sense not to follow through all the way with the downstroke when one is going from high to lower strings. Otherwise, it just feels inefficient.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006217 / 1.052315]
