3 note picking pattern
edited June 2013 in Gypsy Picking Posts: 8
Hi All,
Exercise 8.2 in the Horowitz book leaves me perplexed.
It's basically 3 consecutive descending notes on high e (could be any pattern) followed by same thing on b string. The right hand picking pattern is D U D and D U D.
My question is: I have no trouble completing the first 3 notes. But then once that last downstroke is completed, from there to the first downstroke on the b string seems like such an unnatural leap/jump. It's sort of the opposite of the standard reststroke, in that once it's completed, the pick is not resting anywhere.
And I had though the arpeggios were the main difficulty... shoo wee!
Any thoughts on how to practice this?
TR
    Slowly and with a mind to staying relaxed. All unfamiliar things seem hard until they become familiar.
    What helps me with the whole 'starting every new string with a down stroke' thing is imagining my pick "bouncing" up and off of the string when doing a down stroke before switching strings to another down stroke.
    Anthony
    Thanks Anthon, that helps.
    I'm thinking maybe not following through all the way when I do the downstroke on the last note on the high e string helps before I do the first downstroke on the b string. But I don't know if the picking/tone police would be happy with that.
    I think that there was a thread sometime ago where they were saying that Stochelo does not follow all the way thru on downstrokes when he is doing repeated downstrokes going back up the strings. I think that he calls them 'normal' strokes rather than 'rest' strokes or something like that.
    jonathanmaness
    Bones, that's very helpful! Thanks for pointing that out. If that's the case, then I can see now how it wouldn't feel impossible, I'm seeing improvement from doing that already. It makes a lot of sense not to follow through all the way with the downstroke when one is going from high to lower strings. Otherwise, it just feels inefficient.
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005519 Seconds Memory Usage: 1.000168 Megabytes
