Question about new Guzz pickup series 2...
Hello All! I've recently purchased the new Guzz pickup (series 2) & am still awaiting it's arrival. Just wondering if anyone out there knows how compatible it is to a Gitane D-500. Pretty sure the clip on the pickup won't hold it in place b/c of how close bracing is.. does that sticky stuff work pretty well? And if so, where would you position the pickup on a D Hole guitar? Thank You for any suggestions!
    Many of the Gitane models have a little neck angle which results in very low string clearence. The Guzz is very thin, so it should fit on a D-500, especially since it would be mounted behind the soundhole where the string clearence is a bit higher.
    I will have the Guzz pickup in stock in about two weeks!
  • travisrayletravisrayle ✭✭
    Thank you, really looking forward to gettin' it!
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006194 / 1.062889]
