GJ chord substitutions?
sockeyesockeye Philadelphie sur SchuylkillNew
edited March 2006 in Gypsy Jazz 101 Posts: 366
Does anyone have any good tips on chord substitutions in this idiom?
Advance warning: I know very little about jazz theory so some of what I say below may be incorrect.
I noticed while working on "Blues in Minuer" in Gm that when I go to the Cm6 (IVm6) that chord has a tritone in the m3-6 note pair -- the same interval shows up in the VIIm6, in other words F#m6 (2x12xx). So instead of 2 bars of Cm6 it sounds quite nice if I play 6 beats of Cm6 and then 2 of F#m6 and then back to Gm6.
Would that be a typical GJ sub?
Similarly, when I go to the V7 chord (D7) there's a tritone interval between F# and C. The same interval is in a G#7 but that doesn't sound right resolving to the tonic minor 3rd. The tritone is also in an Ebm6 (x3434x). This sub sounds quite nice, again for the last 2 beats before resolving back to the tonic.
Again, is that something that seems like a reasonable sub for this idiom?
Any tips on books or websites to help me understand which subs I might use where would be appreciated...
    I think a lot of what you can 'get away' with depends on the soloist-I know I've come up with things that sound great in isolation (practicing alone at home), but clash like hell once a lead voice is added. Often it's because of things similar to the examples you mention above: if you look again at the notes, you can still think of them as Cm (ex1) and D7 (ex2), but with altered chord tones (b5 in the Cm, #5 and b9 in the D7). Depending on what kind of sound you're after, things could get confusing.
    That said-if the band likes it, I say go for it! These days I don't actually use true substitutions all that much, but instead use different voicings of the same chord. Simple example for Blues Mineur (Gm 6 beats, Gm 2 beats, into Cm...):
    --x--------x------8---
    --5--------8------8---
    --3--------7------8---
    --5--------8------7---
    --5--------7------x---
    --3--------x------8---
    hope that helps...
    Best,
    Jack.
    Thanks for the tips, guys!
    John
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.033495 / 1.186775]
