string damage at frets
2
  • edited December 2014 Posts: 5,392
    I had it happen with LaBella strings. I went through several sets initially without any winding damage though and then it started happening. So I don't know what changed but I'm not totally convinced it has nothing to do with manufacturing quality control. I emailed the LaBella people and they replied it's common. Ok fine, I ordered a 10 pack through Michael and that was that.
    Had it happen with other brands too by the way.
  • Like @Jazzaferri suggests you may be pressing down to hard. I found myself doing just that and have intentionally worked on not doing so. Playing GJ is different. I never wore strings out like that before either and have been playing for over 40 years. What kind of guitar do you play? Set up on Asians, especially Gitanes like I started on, is usually necessary. My frets had never been sufficiently leveled and polished.
    The wrap is copper, softer than the fret material , so I suppose if you kept on repeating the same passage with a bend over and over again the wrap would wear.
    Guess its time to change your string ?
    edited December 2014 Posts: 542
    The silver plated copper must be comparatively soft next to standard roundwound acoustic strings; I know my flat wounds last for years on my electric guitars.
    Do you remember the original Argentines? The G and D strings wore out in just a couple of days, or maybe just hours. And you even didn't have play the guitar; you could do it just by staring at them and thinking about half-note bends. The New Concept sets are extremely durable in comparison. We are so lucky today!
    @rgrice: I am playing an Asian Dell Arte DG-H1
  • If you press down fairly hard and bend it will cut through a GJ string pretty fast
  • scotscot Virtuoso
    Matteo is exactly right, the old Argentines would wear out in a couple of hours. But they really did sound and play great.
    Re what jazzaferri suggested about pressure on the strings, I taught myself to press the strings as lightly as possible a long time ago when I played a steel-string guitar in dance bands. This was to keep my left hand from wearing out playing rhythm for 10 or 15 minutes during a long contradance. Today I have my guitars fretted with the widest frets possible, and I use a very light touch with my left hand. I wipe off the strings fairly often, too. I use .011 Argentines and my strings do not wear out - even my G doesn't unravel. I only change them when they won't play in tune any more.
    scot wrote: »
    Unrelated to the topic but I'd like to echo this. Wide frets are underestimated, at least on this type of guitar I'll never go back to skinny frets, jumbo only please.
  • Agree with all. I had developed a bad habit of choking the neck and pressing down very hard on strings. I still find myself doing it some but consciously work to avoid it. @Andrew Ulle were the frets dressed and leveled and polished well? If you got it right out of the box, it can be hit or miss.
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005888 Seconds Memory Usage: 0.999222 Megabytes
