Truss rod nut question
rimmrimm Ireland✭✭✭✭ Paul doyle D hole, washburn washington
in Welcome Posts: 605
Basically mine fell out! I quartet turned the rod to bring some relief as I was getting some shimmering on the light strings at 3rd fret. Guitar plays perfectly now, but without the nut will I open the case some day and my guitar may have exploded?
    Hmmm, weird. If it fell out it must have been only held on by a tiny bit of thread and probably wasn't doing anything anyway. I'd clean off the threads on the inside of the nut, put on a tiny bit of lube, and put it back on just barely finger tight to keep the rod from rattling around.
    rimm
    I've put on the bit of lube already-May look at the guitar later on. Thanks for that bones
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005925 / 1.060463]
