Change username or delete profile
ShemiShemi Cardiff✭✭✭
in Welcome Posts: 170
Is there a way to change your username? Failing that, how to I delete my account so I can then sign in via Facebook?
  • I think Michael can change your username
  • ShemiShemi Cardiff✭✭✭
    Thanks Jazzaferri, I appreciate the response :-)
    @shemakimoo you can edit your user name by using the edit profile option (click the little mechanical wheel on the upper right of the screen below your profile name)
    If the system doesn't allow you to edit your profile name let me know and I can do it for you.
    Thanks,
    M
    Hi Michael,
    Thanks for the response, I know you must be busy so I appreciate your reply. I have tried what you suggested but it won't let me change it. I would like to change it to my first name, which is Shemi.
    Thank you :-)
    ok, done!
    Thanks Michael! All the best :-)
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005511 Seconds Memory Usage: 0.999069 Megabytes
