Largest pick
Hi all,
What is the largest (not necessarily thickest) pick you have used to play gypsy jazz? And why?
Thx
    Largest I used was a wegen 5mm. I played rhythm for years with that thing before I bothered starting to learn lead. The 5mm had a fairly round tip and so it swished over the strings nicely, never catching.
    A pick that big is hopeless for any lead playing, much too fat. So later I changed to a 3.5mm, and when my technique improved further I found even that was too fat. 1.5mm-2mm is about right now.
    lewischang88
  • I have used a 5mm rounded and 5mm beveled. Occasionally, I practice with these and use them live but usually use something leaner.
    edited February 2017 Posts: 462
  • altonalton Keene, NH✭✭ 2000 Dell'Arte Long Scale Anouman, Gadjo Modele Francais, Gitane DG-330 John Jorgensen Tuxedo
    I used to use a Wegen 7 that I rounded to the Button profile. Loved the feel for both rhythm and lead. I would still happily use it if it wasn't so damn noisy.
    lewischang88
  • nicksansonenicksansone Amsterdam, The Netherlands✭✭✭✭
    edited February 2017 Posts: 274
    Depends on the player; I know that Reinier Voet plays with a 4 or 5mm, and Fapy and Rino use something around 5mm. I find that to be the ideal thickness ( provided the tip is nicely beveled and rounded) to get a great tone for lead as well as rhythm. As far as largest diameter, 3.5 x 3 cm is the size of the pick i use most of the time, anything larger is hard for me to keep a grip on.
    lewischang88BillDaCostaWilliams
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006731 / 1.052444]
