Case Sizes or Size
I have an Altamira Manouche and just now am getting the action and set up where I need it.
Tbe action was very high and the neck had a wee bit of a bow when I got it.
I have all but eliminated those two issues.
It is inspiring me to play and practice guitar again.
__________________________________________________
It came with a fancy gig bag.
That has been ok around the house while I work on it.
But I plan to go out and play it. So it needs to be protected.
What hard shell cases will work on a 14 fret D Hole, Gypsy Style?
Are there any "surprises" or odd fitting issues?
If I order a Jumbo Case or Archtop Case it should work, but, will it be too deep?
I know that the interior dimensions of cases are often listed or at least obtainable, but is the bonified Gypsy Case a must? Very few are out there and the bottom line is $40 or more above a generic case.
I do not have alot of funds left.
Just wondering, if you have any ideas or feedback is appreciated.
    On Reverb.com see:
    Altamira Hardshell case for Gypsy Jazz style guitar 2018 Black Vinyl $50
  • LeonPLeonP New
    The problem with this cheap hard cases is that they are realy heavy. And its not pleasent to cary that weight around.
    I wonder what hard case is the lightest, maybe something made of aluminium?
    Altamira makes a nice case which will fit perfectly: http://www.djangobooks.com/Item/altamira-deluxe-case
    Although, any Selmer sized case will work so the Superior Deluxe and Gurdian cases will fit as well.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006731 / 1.052444]
