Fingertips all jacked up after too much practicing - any advice?
245
    Wim, the weekend is over, stop practicing and come see what people have said.
    MichaelHorowitz
  • terrassierterrassier France
    Wow pretty impressive ....Imagine if you had to do it all with only two
    I remember playing your guitar. The action was reasonably high and don't you use extra heavy strings for the high e and b?
    edited November 2018 Posts: 1,656
    I try to keep the action between 2-3mm (checking with a black gator at 12th fret). Yes I put a higher tension for the high E and B. Hmm, probably it exacerbate things.
    Is surgical spirit the same as rubbing alcohol? I like the superglue idea, will try that out.
  • Don't put chemicals on your fingers, dude.
    word...
  • especially not superglue...goes right into the bloodstream
    I had some surgery a couple of years ago and they used superglue instead of stitches.
  • normjohnsonnormjohnson ca
    If you're worried get the medical superglue with Octyl Cyanoacrylate.
    Jazzaferri
    edited November 2018 Posts: 6,270
    OK @Wim Glenn , you've now made me feel guilty about not practicing enough! :/
    wimBonesvanmalmsteen
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005903 / 1.053185]
