DeArmond Rhythm Chief 1000 On a gypsy guitar?
Feruza2134Feruza2134 The NetherlandsNew Phoenix D hole guitar
Hi guys, i dont know anything about guitar tech. Is it possible to use a DeArmond rythm chief as a pickup for a gypsy guitar? and what would i need to set it up, because it has like one wire? but what would i connect that wire to and where could i buy it?
So basically if anyone knows what to buy and where to buy to completely setup my gj guitar with a DeArmond please let me know!
EDIT: http://www.djangobooks.com/forum/discussion/16198/dearmond-monkey-on-a-stick-pickup-mount-reproduction
Something like this is what im looking for, what are those volume things, and where can i buy that and how do i connect it all? The guy in forum post says it sounds great!
  • Feruza2134Feruza2134 The NetherlandsNew Phoenix D hole guitar
    How am i supposed to plug that wire into an amplifier?
    haha, im really a newbie so sorry if im not seeing something??
    Ah I see. Yes that one requires some handy work. There's a wired version, Michael sells it:
    http://www.djangobooks.com/Item/dearmond-rhythm-chief-1000-gold-gypsy
    Im in the Eu so i can't pay 200 euro's for shipping while the pickup is 180 haha! What kind of handy work would the pickup require?
    You'd need to solder a female 1/4" jack on it then you can use a standard 1/4 cable to connect to the amp. 10 minute job for someone who can solder.
    I saw in the one picture the guy had like a volume knob, what is that called? could i solder it to that as well and then plug the jack in that?
  • edited March 2019 Posts: 5,842
    That's tone and volume controls. It's more of a convenience, not necessary for pickup to work and unnecessary complication if you're not familiar with this kind of stuff. For example Krivo pickups don't come with tone/volume, just a cable that goes to the amp. Of course you could have it done by someone add tone/volume control to the Rhythm Chief. Tone/volume control that he used is coming from the Kent made pickup, it's a vintage contemporary to the DeArmond, made in Japan.
    Feruza, you can buy a Rhythm Chief way cheaper from Thomann, they're based in Germany - apologies to Michael for this promotion. They are good pickups but not perfect. The balance between strings is good but the b string is slightly louder than the other strings. This is a common problem with most pickups and you just need to adjust your picking a bit. As Buco said you can fit a jack socket or you could solder it to a normal jack plug, I soldered mine to a 10 foot jack to jack lead and cut one jack off. The pickup can be mounted on an oval hole with blu tac/magic putty as the brass mounting rod which comes with the pickup doesn't place the pickup in the right place and you can't bend the rod. I ended up making a brass rod to fit. However that means drilling two small holes in the side of the fingerboard to fit the mounting rod.
    Thanks a lot guys!
    Feruza2134 wrote: »
    Shipping would just be about $17 to the UK for the DeArmond Rhythm Chief.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005877 / 1.060616]
