Best All-Around Studio Amp?
GandyGandy Los AngelesNew Yamaha
Hey guys, looking for quality input here. What is the best all-around studio guitar amp available under the $800-$1000 range? I record a variety of styles, and I'm looking at getting my first decent studio guitar amp for my project studio.
Been reading up on the Peavey Classic 30/112 and Windsor Studio amps: https://youtu.be/pq4mO75vQU0, and they tend to get great reviews: https://waveadvice.com/guitar-amps-under-150/, though most guys change the tubes and speakers eventually to their likings. I'm open to all suggestions, since I'm not a full-blown guitarist and my experience is limited. Thanks...
  • JoseJose Minneapolis New DuPont MD 50
    Hi Gandy, I guess it will depend on what kind of music you want to play, I would also suggest to get a lower wattage amp, 10 or 15 Watts are pretty loud! I own a Mesa Mark 5:25, it is very versatile amp, even though is a high gain amp you can go clean or crazy high gain, it is a 25 watt tube amp and it is pretty loud. If you want to get a tube break sound and if you will use it on a studio get a lower wattage amp, I am planning on getting a Supro 5watt amp.
    rudolfochrist
  • pmgpmg Atherton, CANew Dupont MD50R, Shelley Park Custom, Super 400, 68 Les Paul Deluxe, Stevie Ray Strat
    edited June 2019 Posts: 140
    The Quilter 101 Reverb 50 watt is worth exploring. It is is a very light weight head only (~2 lbs) and is capable of producing a wide range of studio volume sounds. Needs to be matched with a speaker cabinet. I am using a Raezer 12 cabinet which sounds great. I use it for gypsy jazz to blues to rock. Takes pedals well and is plenty loud enough for gigs in larger rooms. I have a Peavey Class 30/112 and love the sound when cranked - but IMO it is too loud for a home studio unless you are able to cut down the gain. Kind of heavy to lug around as well. You can easily put the Quilter in a backpack, carry a lightweight speaker cabinet, and go to a gig on a bus if needed.
    Used ones go for $200 to $300 on Reverb or eBay. Many videos on YouTube.
    I'm always interested in jamming with experienced jazz and gypsy jazz players in the San Francisco - San Jose area. Drop me a line. Bass players welcome!
  • husyhusy Seattle✭✭✭
    @jose somewhat parallel question: Is it possible to explore the range of tones on the Mark 5:25 in actual bedroom volumes without bleeding through the ears, or are you in fact looking to get the Supro 5W because it isn't? I know this is a topic that's been discussed countless times on other forums, but something tells me your opinion will be more reliable than that of the typical amp forum participant.
    i feel you can somewhat explore at bedroom levels but is limited, I believe a tube amp sounds best when it is cranked up but when you have 100 or 50 Watts of tube power is near impossible, the mark 525 is a 25 watt amp and you can also operate @10 Watts but 10 Watts is still pretty loud even on a live setting when you have a loud drummer, I usually adjust eq according to volume and the room I am playing and yes I do want an amp that won’t bleed my ears, on top of that it is easier to haul around smaller amps, achieve good tone and have happy sound engineers.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.016333 / 2.710335]
