No clue unless it was for a truss rod nut. Or maybe they used it to fixture the body during the build???
crookedpinkyGlasgow✭✭✭✭Alex Bishop D Hole, Altamira M & JWC D hole
Selmers didn't have trussrods, they had 'duralinium' reinforcement bars in the neck, so it's definitely nothing to do with a trussrod. I'm sure I've seen similar openings in some modern makers builds, maybe they'll chip in on this discussion.
I wonder if the Charles Selmer book might shed some light on this, I'll look later.
I don't have the book so i'm curious. There are some acoustic guitars who have the trussrod nut in the neckblock but not the selmers. Like you said.
And yes, perhaps a construction issue..
Thanks for the comments, i keep searching....:-)
According to the book it was for a threaded rod which was used to hold the body together when it was being glued together.
Ah, ok. Thanks very much!?️
