Neck Adjustment When Changing String Gauge?
jonpowljonpowl Hercules, CA✭✭✭ Dupont MD-100, Altamira M01F
in Welcome Posts: 713
Is it ever necessary to adjust the neck relief when going from 10s to 11s or vice versa with gypsy guitars? Both of my guitars have fairly chunky necks with truss rods.
  • edited May 2015 Posts: 3,707
    I just switched my Dunn from 11,s to 10's. After a day or so of settling in, the curve was a bit different so I took a bit of tension off the truss rod.
    Check the action and curve before and after. Your eye and common sense will tell you whether you need to change the truss rod.
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005525 Seconds Memory Usage: 0.999069 Megabytes
