Holding the pick; Feedback
jpipper17jpipper17 New Saga Cigano GJ-10
in Technique Posts: 34
I am new to the boards. I would appreciate anybody's feedback on my pickhand technique
Shemi
«1345
    Looks good! You might want to go read sideways.
  • stuologystuology New
    Yeah those picks sound best with the rounded edge
  • jeffmatzjeffmatz ChicagoNew
    Downward slant us fine, but the angle might thin up your sound.
    I’m all about the downward slant !
  • jpipper17jpipper17 New Saga Cigano GJ-10
    jeffmatz wrote: »
    Could you perhaps post a picture of an alternative way to hold the pick?
  • ShemiShemi Cardiff✭✭✭
    If you look at the thread Win posted there are pictures to help to, but this technique generally has the pick flatter to the string instead of the the diagonal angle that you would use in other styles, which is what you seem to be doing in the first picture
    I'm just getting back into this style after years of playing only electric jazz, and the downward slant and flat angle have been the two biggest things I've needed to work on, but I can hear the difference instantly.
  • edited August 2018 Posts: 5,375
    Seems to me angled is what Stochelo is doing:
    it's whatever works for individual though, whenever you hear "this is the way x should be done" there is somebody of the high caliber that's doing the opposite. Whenever I hear "you should try using very small finger movements when playing fast, economy of motion" and what not, Pat Martino comes to mind as his fingers are bouncing off the fretboard between the notes.
    I couldn't find a video with a clear shot but Tchavolo might be a player with a flat-er pick position.
    NewcastleBudBillDaCostaWilliams
    Might be angled a bit, but it'd also be the oposite angle of what the OP posted.
    You can definitely see a downward pick slant, though, and a loosey goosey wrist...
    edited August 2018 Posts: 170
    Hey Buco, didn't mean it to come across as "it needs to be done x way", it's pretty obvious there are many ways to skin a cat. I see lots of forward pickslanting in the Stochelo vid, but I don't see as much angle as you would commonly see with a player in modern styles. I was lead to believe by some reputable online resources and my own observationthat the flatter pick attack allows for more volume as more pick goes through the string. As you angle more you get more bite but there is less pick moving through the string which can be an advantage or disadvantage depending on what you're looking for. It's all generalities though!
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005668 Seconds Memory Usage: 1.009209 Megabytes
