Altamira Deluxe Tuners NOT an exact fit for their basic ones
Hey friends,
Just received my M01D from Michael and I love it so much. It’s so much better than the other Asian budget GJ guitars I’ve come across at box stores. It’s got such a loud bark that will really help me develop my right hand techniques and dynamics for the style as compared to my archtop and flattop.
Anyway, I had a spare DR tailpiece from LMII before they closed down so I swapped that onto the guitar right away for the red leather and brighter looking brass. I also had bought the deluxe tuners after reading about the base model reliability down the road. The posts obviously fit fine but the screw holes don’t quite align. I should’ve taken a pic while I was sussing it out but the screw hole closest to the nut is aligned, every next screw hole is slightly closer together on the deluxe plate. To the point where the last hole is visible beyond the deluxe plate.
Plugging those holes and redrilling new pilot holes is totally something I can do at the next string change; I just didn’t feel like undertaking all of that on my first day with the guitar. Thought it would be good to make this post for anyone considering replacing the Kluson style tuners with the Altamira Deluxe ones. Just know there’s a tiny bit of labor that’ll need to be done!
  • richter4208richter4208 ✭✭✭
    Mine has the Schaller classics on it. It turned me into a fan of these tuners. Love them.
    https://www.djangobooks.com/Item/schaller-three-on-a-plate
    @Brunerd1489 I don’t think there is a single Gypsy tuner that will “drop in” as a replacement for another tuner. There will always be differences in screw hole placement, shaft length, etc. A good tech can deal with these minor differences and make the transition seamless.
    I'm not suggesting that you can't do that job if you have some Lutherie experience. But personally this is one of my least favorite jobs, pretty easy to screw up badly and hard to do a really nice job. It is very easy to crack the headstock when drilling. I should get a hand drill for this now that I think about it.
    Brunerd1489
  • jmanjman New
    I replaced the above mentioned Schallers on my md50 with miller tuners. There is a really great tech in my town and he made mahogany side grain plugs for the old screw holes. I am with Paul makes sense to have someone with experience do this job, especially if there is some overlap with the screw holes on the new tuners.
  • Brunerd1489Brunerd1489 VA (southeast)New Altamira M01D
    Only the last holes are visible and I feel competent to do this and make it relatively invisible, just not now with PT school and homework and all of that. I've got a dremel with tiny drill bits for the pilot holes and I would ideally find some tiny side grain mahogany to plug the 2 visible holes, use a toothpick and glue for the 4 hidden ones
    It's not like this guitar is a sacred cow or anything. Lord knows I've already added some pick scratches.
    jman
    Just wanted to update on this. Tried doing this mod and found that when I went to install the other side tuners, they don't fit! The shafts are too long for the slotted headstock to fit both sides on so it looks like I'll be sticking with the budget tuners.
    Also, does anyone need some deluxe Altamira tuners?
    You could just grind the shafts, I've heard of people having to do that to fit the two opposite sides. Is it only at the top, G and D strings?
    oh yeah, I always have to take a bit off on the D and G string shafts regardless of the tuner. I use a stationary belt sander. You have to make sure you debur the edges (with a file or sandpaper) when you're done.
    Pro Tip: don't grind them too short. I have yet to, luckily, but it's entirely possible.
    You could do it with a file too. Or a dremel with a cutoff wheel (eye protection). A belt sander with 80 grit is my usual vaporizer of things so that's what I use.
    Hold on tight as it would be easy to lose control of any of these things and do some damage.
    Ya know, after I posted this the thought occurred that I could just take some length off the end. Gentlemen, you are right and I will do so, once I'm cleared for more intense activity. I'm in a sling after some shoulder debridement over the weekend and need to do some PT.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.015927 / 3.886459]
