Cheap/Reliable Amps
Hey!
I have been using the Tanglewood T6 amp my entire life for gigs, but recently it's been getting quieter and hasn't had the punch that I've needed for bar gigs and medium sized venues. I wanted to get a henricksen Bud, but they have gotten really expensive. I love that the Bud is 2 channels and can connect to bluetooth. Are there any good, cheap alternatives? I use a peche, and want to get a cs sensor for context on my pickup situation.
Thanks,
Josiah
    Before I got my Henriksen Blu 6, I used a (now discontinued) Roland AC-60, which has plenty of power, two channels, decent sound shaping, and lots of I/O. Roland doesn't seem to have anything equivalent in their line any more, but they do seem to show up used. (Which is how I got mine.)
    I would still be using the Roland if it weighed as little as the Henriksen, but my ancient shoulders overruled my equally ancient ears.
    Boss Katana 100 to me is an amazing value. The modeling amps are great but it also has a power amp input (so no modeling, just a flat amplifier) so you can put anything you want in front of it (IR/NAM thing, amp modeler, HX Stomp, whatever).
    Has 3 different power levels so you can use it as a practice amp but also pretty loud. Tons of onboard effects that are apparently the same as Boss pedals and super useful.
    At the moment I just run my hx stomp pedalboard into the power amp but I need to work on some presets so I could just plug straight into the amp if I don't want to carry a lot.
    Personally for me there is no 2nd choice to this but I don't give a shit about real tubes.
    Bucofauves01
  • edited April 28 Posts: 6,074
    Katana sounds like an amazing value. I don't see how you could go wrong. There are a few on Amazon selling"used - like new" for $400, even under. A lot of times people return stuff as soon as they see the packaging scuffed up, that could be the case here. One video I watched that's demoing it with an acoustic guitar, says it has a dedicated premap with no modeling involved and the guy loved as a pure acoustic amp.
    But also try getting your amp serviced. By the sound of it, it might just need capacitors replaced.
    I should mention that there's like 3 generations of the Katana. I think they are probably all great, I think a lot of it is the connectivity improvements.
    The one thing I hate about it is to get Bluetooth you need to buy this dongle thing that sticks in the back and it seems to always need you to press the button on the back to get it to pair (Like once a session) Annoying AF.
    Otherwise it's awesome. And yeah it has an acoustic channel which I think probably has limited coloring but I haven't used it yet. New guitar will have a piezo so I might try it then.
    The acoustic channel does sound good on the Katana. I find it similar to AER, Bugera, etc. very transparent and clean with not much coloring of tone.
    Speaking of tone, the Katana amps have a global EQ that can be accessed via the editor when plugged into a computer. If you find the amp overly bright by default you can change the global EQ to tame things. I didn't find the amp very usable for jazz until I did that.
    paulmcevoy75Buco
    Yeah I think most generic amp sounds lean towards metal sounds. I haven't played with the onboard sounds very much because my Stomp is sounding heavenly through it.
  • marcelodamonmarcelodamon Asheville, NC✭✭✭ Django's Selmer #560, and various others
    Hello Josiah!
    Did you find an amp that suits your needs? I would recommend a Hughes & Kettner Era 1, or a Carvin AG-100D:
    Used Hughes & Kettner Era 1 Guitar Combo Amp | Guitar Center
    Used Carvin AG100D Solid State Guitar Amp 1 x 12
    These are both affordable, and offer great sound.
    Nice finds! Great price on the Era 1 but the Carvin is absolutely a bargain. If I was buying a new amp, Era 1 or even Era 2 would be my first choice.
    There's a new offering from Hughes and Kettner, Era C. Two channel, (they market it as 4 channel but two additional channels are aux in and FX return) 60W with 8 inch speaker. It's still not distributed in the US but is looks like it'll be under $500. Which is a really good price for the quality of H&K.
    flaco
    After recommending the Katana a bunch here (and I still love it) I was thinking that with the modeler stuff I'm using and running those into the power amp on the katana, I might be fine with just a powered speaker. I ordered an Alto TX 410 for like $169 at Sweetwater. I should be able to plug either my HX Stomp or my Smartbox in there. I also have a Yamaha mixer so I should be able to run the internal mic straight into the speaker through that (it needs phantom power, I think the mixer has that but I have to check).
    Anyway I'll report back.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006847 / 1.063232]
