D'Addario Humidification System
JSantaJSanta NY✭✭✭ Duffell, Gaffiero, AJL
Hi All,
I have the D'Addario humidication packs for my acoustic instruments, but the petite bouche has a small soundhole compared to a normal flattop. I am able to get the packs in the soundhole with a bit of maneuvering, but I'm wondering if anyone else here are using them? I live in the NE United States, and run our furnace from Novemberish-Aprilish each year. The guitars are kept in their cases. I run a humidifier in the room and it's usually about 45% RH in the room.
Am I being overly paranoid about putting the packs in the guitar?
    I thought 45 percent is right where it should be. Room humidity can drop to 20s but as long as I keep the guitar inside the case with the damp-it, no problem.
    That's my understanding as well, thanks Buco. I have had the same humidipaks in my flattop for a year and they haven't needed replacing, which I suspect is due to where I keep the humidity in the room, and that the guitars are kept in cases.
    The Eastman DM1 I purchased only came with a gigbag, which I'm sure isn't as robust at keeping humidity and temperature as consistent as a HSC. Eventually I'll get a better case for the guitar. I'm honestly surprised Eastman isn't shipping these with hardshell cases, while they do with similarly priced flattops.
  • edited February 2020 Posts: 5,755
    That's too bad, they have really nice hard cases for their archtops. But I wouldn't think a decent gig bag would not do any worse then a hardcase at preserving humidity. My thinking is as long as the wood isn't in a direct contact with dry air it'll do fine in a gig bag.
    JSanta
    edited February 2020 Posts: 3,338
    Yeah keep the room at 45-50%RH and you can just put the packet in the case if it's a tight fit???
    JSanta
    I can probably just do that and really not worry about it otherwise.
    I think I'm just being paranoid.
    PS- don't store the case near a window or exterior wall.
    Always good advice :)
    I still think I'd like to get a HSC for this guitar eventually. I'll probably take the humidipaks out of the soundhole, keep one in the bag, and make sure my humidifier is going.
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005649 Seconds Memory Usage: 1.010307 Megabytes
