Simplifying changes
13567
  • TwangTwang New
    This is exactly right Bones (and Buco) many thanks and to all the other contributors here. Some great advice, I’m feeling better already!
  • TwangTwang New
  • spatzospatzo Virtuoso
    ok !
    I think that a good way to solo on After You've Gone is to point the guidetones that make a line through the chords :
    e eb d c# c b g
    TwangBonesvanmalmsteen
    Exactly, thanks @Bones that why playing a solo that follows the key mostly works and it usually won't sound "wrong". On the other hand trying to chase a chord and play chord tones over unintended chord might.
    TwangPassacaglia
  • TwangTwang New
    Do you think a lot of players think in keys centres rather than chords then Buco? I could argue that it’s easier to generate melodic ideas with chords but I think I’d be on shakey ground here.
    what If I said the best melodies most often come from arpeggios? 🤭
  • edited May 2020 Posts: 376
    I do not think most people think in key centres. There are many times where that will clash unintentionally.
    Twang
  • TwangTwang New
    I agree but it’s do-able if you know where the harmonic pitfalls are and can side step them I suppose.
    I mean even scales are arpeggios if you’re thinking of a big enough chord voicing
    That's true, but if you take the time to figure out the pit falls and how to avoid them you might as well just spend the time working on soloing over the chords. It feels like a fools errand otherwise.
    Where a key centre would work well would be if you are playing kind of blue 🙃.
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005528 Seconds Memory Usage: 1.009209 Megabytes
