G strings
All joking aside, it seems my g strings wear out faster than all my other strings. I use Argentines, and about once a month they start to separate around the 7th Fret. All the other strings are fine.
Does this happen to anyone else? Am I doing lots of g bends?
Is this a known phenomenon?
It's annoying and expensive. I just bought a pack of single G's.
«13
    edited May 2021 Posts: 1,887
    Yeah, same thing happens to me too... so I guess you could call it a known phenomenon.
    I guess the G string is just the most vulnerable string, being the smallest wound string.
    If anybody knows something to be done about it, please! I would like to know about that, too.
    littlemark
    It's normal. A pack of single G's in the guitar case seems to be a popular mitigation. Surprising how replacing only that dead G can bring a fresh sound back to the whole guitar.
    Another way around that's less common, try using an unwound G. Savarez don't make them, but it's pretty easy to find whatever brand regular acoustic guitar strings with unwound G. Think I used Dean Markley's. It worked well and maybe even sounded better for those tunes which have some melody notes played all the way down to the G strings.
    rudolfochristBonesBuco
    Interesting. I've never played non wound G's. I use heavy strings usually.
    I recall reading somewhere on the forum people discussing a method of giving a few twists to their strings (I think this was easier with loop ends) and that seemed to prolong the useful life of Gs.
    For what it's worth, it hasn't happened to me with Optima strings.
    #thisonesforourfallenGs
    What do you mean a few twists?
    yup, common issue. they sell individual strings.
    To tighten the string windings. I don't know the exact method.
    Perhaps someone will correct me if that's not the correct word. 🤣
    PS: After a quick search; that seems to be to brighten dead-sounding strings rather than to prevent string wear.
  • MikeKMikeK Asheville, NCNew Altamira M-30 D-Cedar
    If I'm not mistaken, the g string in a set of Argies has the most tension on it of all the strings. Michael, or many of the others on this forum with more knowledge than me, may know for sure. I know that when I go to change my strings & cut the g with my wire cutters, it makes the loudest pop of the bunch, and sometimes the section of the string with the loop on it shoots across the room. Maybe that's at play with the wearing out of it? Regardless, I'd say you're doing well to get a month out of your sets. That's when I change mine, always trying to catch them before the intonation starts to go. It also precludes my breaking a string at a gig.
    edited May 2021 Posts: 1,599
    That is correct.
    Tensions for 1510MF gauges
    Tensions for 1510 gauges
    The twist trick means taking the loop end off the tailpiece, turning the loop over a few times and popping it back on. I've never tried it, in all honesty, but I'm sort of skeptical about that making any difference beyond a placebo effect :)
    BucorudolfochristBillDaCostaWilliams
    Hey MikeK. You might want to slack the strings a bit before you cut them off??? IDK if it makes any diff but I slack them.
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005807 Seconds Memory Usage: 0.999222 Megabytes
