Left Hand Wrist Pain
Does anyone else have this problem. Is it related to the wide flat necks? I play other acoustics but only the manouche hurts my wrist. Thanks
    I've heard that switching between neck sizes can cause some problems. Maybe you need to change the neck position while playing the manouche ... point the neck more in an upwards direction?
  • lindaketlindaket New
    It could be caused by that, but you should rather get it checked, just in case it might be a carpal tunnel or similar.
