Django sometimes used fingerpicking, right?
Like "Tears" or "Improvisation No.2" for instance.
(Chord notes are sounded simultaneously -indicative of the use of right hand fingers as opposed to plectrum)
This is something I've been trying to find corroboration on for ages but I can never find anyone talking about it.
Or even a mention of it anywhere..
Is it something that is "known" among the community of guitarists? - is it the case, even? - or am I wrong?
I wondered if anyone might have a link to somewhere that discusses this question in some depth??
  • bluemovesbluemoves New
    also sounds like he's using some sort of rasgueado abanico at 2:10 here: https://www.youtube.com/watch?v=XeZqVuH6QoE
    which would seem to suggest he isn't 'hybrid' picking with a pick between thumb and first finger.
    wim
    I’ve seen pictures where he is playing with no pick. Never in a group situation of course, with the volume discrepancy I can see why that would be a problem
    Judging by Stephane Wrembel's meticulously transcribed solo works he did.
    vanmalmsteenJSanta
    He definitely did. Off hand, I can think of “Improvisation No2”, the first version of “Tears”, “Naguine” and “Tea for Two”. They may be others I have missed. He also used “finger picking” briefly on other recordings for effect.
    It also sounds like he's using his fingers on the intro chords for Imrpov #3 and the intro for I'll See You in My Dreams.
    richter4208
    also interesting is that I remember once seeing a a photo where you could see his right hand clearly enough to notice he kept his finger nails long enough that could potentially being using them to finger pick, also in many photos he’s playing without a pick, obviously most of those were just poses but it’s interesting that he almost always holds the same hand position, floating wrist, but much straighter than classical posture, positioned so it seems he used all of his fingers which sounds right based on the recordings.
    edited July 2021 Posts: 395
    And towards the end of Improvisation nr 3, both part 1 and part 2. Also, the theme in Oriental Shuffle. Here I suspect he might have used the pick and two fingers to have the pick ready for the improvised phrases in the last two bars of the "A" parts, particularly the very fast phrase in bars 7 and 8.
    MichaelHorowitz
  • MondoslugMondoslug New
    You would think pick and fingers at least on some of the stuff…Django authority that I am not.
