Castelluccia tuners
DragonPLDragonPL Maryland✭✭ Dell Arte Hommage, Leveller Boogie-Woogie, Castelluccia Tears, Yunzhi gypsy jazz guitar, Gitane DG-320 and DG-250M, Altamira M01D Travel
My Castelluccia tuning peg gear has totally worn out, to the point I can't twist it to even tighten or release the string.
Anyone have any advice on how to proceed? Replace the whole side tuning strip? Just the gear?
If so, what are the specifications; gear ratio, tuners? What are these tuners? Are they an old Schaller tuners? They don't look like the Schaller tuners sold here.
Any help is appreciated.
    Looks ok to me from this photo - are you sure it's the gear that's stripped? I'm sure a new cog could be found as a replacement if it really is that. Are you sure it's not the ivory winder that's turning on the spindle?
  • DragonPLDragonPL Maryland✭✭ Dell Arte Hommage, Leveller Boogie-Woogie, Castelluccia Tears, Yunzhi gypsy jazz guitar, Gitane DG-320 and DG-250M, Altamira M01D Travel
    edited January 2023 Posts: 210
    Maybe the picture does not show it well, but the four teeth on the gear, touching the tuning screw, are stripped.
    Ah righto, sorry!! I would hope someone here could point you in the right direction of spares.
    Do you know what caused the teeth in just that section to degrade so much? It might seem to me that is some sort of misalignment that would cause it there? If so, you might not want to put a new gear in there, even if it were possible, as it might happen again. I'd probably consider buying a new plate. Have you tried contacting Castellucia? Perhaps there is some sort of warranty on parts?
    Jangle_Jamie
    That particular string tuner was always hard to turn. I just never payed it much attention, and here we are.
    Thanks for the suggestion to contact them, I just did, lets see what they come back with.
    billyshakesJangle_Jamie
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.015898 / 3.912621]
