CS Sensor Pickup
Hi!
I have a few shows where I need to amplify for the first time ever. I have a cs sensor pickup and an AER60.
I see how this pickup is meant to be installed, but if you put the cable jack part by the end pin on the tailpiece, it doesn't fit in the case. See the **** video. I put it on like he did.
Are these made to be taken on and off after each use? Will the double sided tape allow for this? Do you have any tips?
