Dunn guitar - truss rod adjustment
DragonPLDragonPL Maryland✭✭ Dell Arte Hommage, Castelluccia Tears, Yunzhi gypsy jazz guitar, Gitane DG-320, DG-250M and DG-250, Altamira M01D Travel
edited May 2024 in FAQ Posts: 207
Just like everything is unique on a Michael Dunn guitar, so is the truss rod.
Anyone know how to adjust it????
No hex wrench fits it, and can't fit a regular wrench there to twist it either, if that's how it's done on it.
    Hard to tell but looks like maybe it's a bit stripped?? Either way, I'd take to a luthier before messing around with it too much more.
    You might try to ask Shelley Park if you don't find any responses here. I think she might have worked with him for a while. At least they lived and built guitars in the same town. She probably has seen more than one of his guitars.
    DragonPL
    I actually messaged him on Messenger, but not sure if he reads those. His old website is not up anymore so I don't have his contact.
    What’s the problem you are trying to solve?
    (Is the fingerboard very flat if you put a ruler on it? If it is, I would recommend leaving the truss rod torque as-is)
    Hard to tell from the picture but is it designed to use a right angle truss rod wrench that slips over the nut? I have a few guitars with those. It's no problem to adjust the truss rod if you want more/less relief. It shouldn't be used to change the action. Just mentioning because there are a few videos out there from well known Selmer style guitar luthiers that wildly misrepresent what the truss rod is for.
    https://www.sweetwater.com/store/detail/TRWrench--taylor-truss-rod-wrench-steel-string?srsltid=AfmBOorSAAzgDw7RsoRD2WpHJ-gbAVVVSEP4z-t92RWRSmLu0BR9Uqz1bf0
    DragonPL
    About the truss rod nut itself: it might be metric rather than English--I bought some metric hex wrenches for just such situations. (I also have a Dunn guitar but have never needed to adjust the relief.)
    About contacting Michael: If he doesn't check his messages, maybe just post directly to his FB page, which I know he attends to because he posts there himself.
    Thanks!!!! That wranch did it!!! (Got the same style but in three sizes of Amazon, and one of them worked)
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.016603 / 3.885864]
