Maximum bpm for rest stroke
This is just a theory.
This is a rough estimate. Objects fall at about 4.9 centimeters per second. This is about 2 inches (1.92913 to be exact) per second. If you start your down stroke about 1/4 inch above the string, it will take about 1/8 of a second to hit the string, or 240 bpm, which is the maximum bpm for the most relaxed down stroke, just to reach the string. This does not factor in passing through the sting and coming back up. Without doing the math, I think you can determine that, in order to play at 300 bpm, a fully relaxed wrist that uses only gravity is not possible, but muscles must be used.
#nerdfest
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006659 / 1.255722]
