DuPont truss rod location question
casscass Pennsylvania New AJL XO, DuPont MD100, Gitane DG255
My MD100 has developed a buzz on certain notes and when I tap on the neck I hear a rattle. I’m thinking the truss rod has some play in it and if I give it a slight bit of tension it may help. I have ruled out frets, bridge, tail piece and nut. My neck relief is good. My problem is the hex wrench supplied with the guitar doesn’t seem to reach the nut. I have only tried from the exterior of the guitar. My hand is a bit large to try to fit it and the wrench in the sound hole. I’m afraid I’ll drop the wrench inside. Does anyone have experience with this? Thank you, Jim
  • jmanjman New
    Hi cass,
    I have a couple of duponts and have adjusted them quite a bit. You need the long part of the truss rod to push in up close to the top if that makes sense. It can be a bit of a challenge to get it in the hole that’s drilled in the upper traverse brace without damaging the sound hole. Another option which I prefer is to use a long handled ball end Allen wrench of the same size, then put the whole thing in the guitar and spin it around once the truss rod is in place but not yet engaged in the truss rod. I have a small rare earth magnet that really helps with this but I can do it easily with just my fingertips and the strings loosened. To turn you can use something as leverage on the small part of the wrench which should be poking out the sound hole. I use a small piece of aluminium tube. I have had truss rod rattle in other guitars and you should only need to tighten it a tiny bit, less than 1/8th of a turn. Hope this helps.
  • casscass Pennsylvania New AJL XO, DuPont MD100, Gitane DG255
    Thank you Jman!
    I think I need a longer hex wrench. The one I received with the guitar doesn’t have a longer side. It’s approx 3” x 3”.
    edited July 2025 Posts: 158
    Your problem could indeed be a rattling truss rod, I’m familiar with the issue. Snugging it (truss rod) up without torquing it either way might help.
    The 4mm version of this is the best tool IMO for adjusting a Django axe (4mm is pretty standard, DuPont uses 4mm). Works in an O and a D, no need to cram your hand in the hole.
    (Advice: Be ultra-conservative in making truss rod adjustments, 1/4 turn is the absolute max you should turn the truss rod nut, then wait 30 minutes for the neck to absorb the change and try/measure the guitar again).
    Tool you want is Item #6212: “For 4mm nut; triple-bend with 5-3/4" reach”:
    https://www.stewmac.com/luthier-tools-and-supplies/types-of-tools/wrenches/soundhole-truss-rod-wrenches/?gad_source=1&gad_campaignid=17282679006&gbraid=0AAAAADcBv9gGNa0GcncpjXwTCBKsFZ5-U&gclid=EAIaIQobChMIpcPR27vAjgMVnjcIBR3YkgkKEAQYBSABEgKlV_D_BE
    It may take a while for the guitar to adjust, if you turn the truss rod nut much. You might have to wait a day to see how the neck -- and body -- respond (the action may change, strings will pull differently on the tailpiece, potentially affecting downward pressure of the bridge on the top),
  • jmanjman New
    edited July 2025 Posts: 16
    Here is a photo of the DuPont truss rod wrench next to a standard ball end wrench you can get from a hardware store. Also included the bit of pipe I use on the end for leverage once the wrench is engaged. The length of the long end is 5.5 inch (the part you will need to pass into the hole in the upper traverse brace and then into the truss rod).
    While I agree with the above statement for adjusting relief, you should be able to tell if it worked for the rattle instantly. Some rattles cannot be solved this way and will been to be fixed by a luthier, usually by drilling out a fret marker and injecting something into the cavity that houses the rod.
    If you're not confident with truss rod adjustment it's an excellent one to bring to a (good) luthier. You can do a lot of damage pretty easily.
    You shouldn't need to actually adjust the truss rod if the relief is where you want it. You'll know immediately if it is loose to the point of rattling and it won't take much turning to tighten things.
    Thank you everyone for the excellent feedback! I’m glad I asked the question.
    Jim
    Have the same issue with my Dupont Favino, must be a Dupont short truss rod thing. I typically tighten the truss rod with that long wrench a bit, and the noise goes away.
    edited July 2025 Posts: 33
    My truss rod rattle is fixed. I purchased a 5-3/4” hex wrench and it took less than 1/8 of a turn! Thank you All,
    Cass
    Gouchjman
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006957 / 1.060463]
