Kleio vs Peche
This discussion was created from comments split from: Why buy an expensive acoustic amp?.
JSanta
    I don’t want to totally derail this thread, but since you have both I’d be interested in hearing your thoughts about the Kleio vs. the Peche.
    In the mix they sound similar and I doubt most people would hear an audible difference sitting in front of the band. I find the Kleio has a little more presence in the top end while the Peche sounds a little beefier. If it's just me at home playing by myself into an amp I generally prefer the Peche but I always use the Kleio on gigs and at jams. The Peche is heavy which makes it want to come off the guitar if you stand up and rotate the guitar without removing the pickup first. The Kleio stays on better. I have an older Peche w/ the attached cable which is also kind of annoying on gigs.
    Thanks! I always wanted a Peche, tried to buy a used one, and it arrived broken. I was able to buy a Kleio, but it’s always been in the back of my mind that the Peche may have been better! I noticed that Stephane Wrembel has converted from the Peche to the Kleio. During my limited time with a Krivo I know that I definitely prefer a detachable cable.
    edited February 26 Posts: 381
    He's been using the Kleio for at least a few years. And the reason I bought one over the Peche or other options. I'd still like to try a Peche at some point, as well as the Miller Flèche d'Or, but I'm really happy with the Kleio. It stays on the guitar, sounds great, and responds fantastic to pedals.
    To be fair, I've only used this rig at one gig, but I have a Strymon Flint (LOVE it), a GE-7 equalizer, Hum Debugger, the Fairfield Barbershop, and a small volume pedal. I've also got a POG laying around, but unlike Stephane, it sounds like hot garbage when I try to use (the pedal itself is awesome, it's just that I'm not).
    I love my Peche but I'm really thinking about grabbing a Krivo at some point simply due to the slim profile and simply being less cumbersome in general (also, the Peche isn't compatible with Altamiras...which bums me out when I want to play out with my Altamira lol).
    That said, I've compared them before and while I do prefer the Peche's tone a little bit more, the difference is pretty negligible; in addition to the reasons above, that's also why I'm hedging on potentially replacing the Peche out at some point now because all the plusses combined of a Krivo really seem to make it the best magnetic option on the market rn.
    Just within the last few months I bought a Krivo with the thought that it might be the perfect solution, a little less electric sounding than the Kleio. That is true, but one thing I found that if I used extra putty to boost the Krivo closer to the strings I could get it to sound close to the Kleio. If I didn’t have the Kleio I could be totally fine with the Krivo.
    voutoreenie
    Wow I feel dumb now...I read Krivo the entire time lmao
    flaco
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005816 / 1.052689]
