You bought one too? The OP is a local friend, he's selling his backup Lunchbox (he's got a portable Bose amp and another ZT that he's keeping) which is practically new. As he said, he tried it out to make sure it works and then used his other amp to gig with. A great amp from the great guy.
If it's done deal then, I replaced the original speaker in mine (the buyer has the original speaker as well) with this one because I wanted a full range speaker:
Oh man that's good to know. The guy refused a return. Honestly I'd be happy to keep it if I could get it to work and I was wondering what speaker would fit as the size seems not standard.
Yes, that's the speaker that was at the DiJ jam. It dropped in the opening, only the lip of the new speaker is only a 1/16 wider (that part of the cabinet where the lip of the speaker sits is recessed slightly so that it sits flush with the cabinet) so that part had to be widened a touch.
paging @Buco (I just bought one on Reverb)
Yeah I bought it like 10 seconds after seeing it.
Turns out mine has a blown speaker. Oh well.
Bummer, sorry to hear that.
You should return it and buy my friend's.
https://a.co/d/05OZFMNq
It wasn't quite a drop in replacement, a touch of lip opening needed to be widened but it was a quick job. The specs are the same otherwise.
But you should buy the one from the OP.
Did you have to route the opening in the amp?
Is that the speaker that was in it at DIJ?
