A free interactive tool for gypsy jazz — arpeggios, chords, play-along standards
124»
  • axelaxel New
    Oh thanks for your feedback, I worked "hard" to make it happen with synth samples ahahah, yes I tried to have an "upstroke"; "swing" feel and the "delay effect" was the best I could do honestly ..
    But since I made it happen... probably have a classic developer bias. Definitely something easy to fix.
    On the overwhelming part
    I'll try to make another pass of improvements, definitely better than last week but still.. I agree. If you've got suggestions I'm all ears.
  • lorenzoplorenzop Madison Wi & TucsonNew Risto Ivanovski
    edited 7:57AM Posts: 75
    In Buco's lick, what are the numbers in the circles? I suspect they are scale tone numbers, but they seem off. In my opinion, scale tone #'s above 7 is being sesquipedalian.
    axel
  • axelaxel New
    They are the order to play them, since every note is shown in the same view, not as a long tab.
    Not sure that's the proper approach.
  • axelaxel New
    Hey guys, just letting you know i'm fixing the overall registration form with simple Emails.
    Apparently that's a paid Feature of Firebase (which i'm using for login) so I fixed that 😂.
    And now quickly working on fixing the profile section that doesn't work if you're not already inside "community" which is quite dumb 😂.
    By the way, if a Bastian is here I thank you a lot for your incredible donation 😍😘.
  • edited 10:56AM Posts: 6,050
    Is it possible to animate them so the note that's being played is highlighted and the rest are gray?
    Then you can put note letters in the circle.
    axel
  • axelaxel New
    There is definitely something to be improved here yes, It is animated but whey notes stacked it's not very visible.
    I'll try to improve, as you say probably grayed.
    Do you think I should keep a vew "stacked" like this ? Or more "timeline based" ? like it shows only the current and the next bar when playing?
    While I can keep stacked when showing the lick before it's played.
    What do you think ?
  • edited 2:45PM Posts: 6,050
    Actually, you were already highlighting the current note, I wasn't awake when I wrote that, sorry. But the numbers are confusing to me too. I can't figure out what they follow.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005934 / 1.052612]
