Ukulele versions
13»
    That's neat to see how the tonic walks down to the Maj7 (keeping the b3 & 5) but then instead of going one more fret down to the b7, you return that string to the tonic G and eliminate the 5 (weaker tone in the chord anyway) to pick up the b7 on the other string and also allowing easy step movement to the 6.
    Samy "Daphne" melody 'head' chords from Sept. 17 2017 video that no posted video links here show this. These 3 and 4 note low rhythm chords are filled by the high note of the 2 note octave melody head!
    Notes in( ) are optional for added fullness.
    Key DM 1st measure 5x44(5)x
    2nd measure 3x24xx(My inversion Em) 5456xx
    REPEAT A above
    5th measure 5x44(5)x 5x45xx
    6th measure x554xx 4x34xx
    DM - A7 turnaround chords above(2 measures your choice to phrase it).I like his choice of minimal chords here!
  • djazzydjazzy New Castelluccia, Riccardo Mordeglia, AJL
    this guy has a pretty good youtube channel...
    spatzo
    The advantage of such method is to use as few fingers as possible three or two only and to be able to fret the chord as quickly as needed. A simple position is also easy to memorize. But also and above all the sound is kept more compact and discrete not too high-pitched. You must back-up the soloist and not disturb him or invade him.
    This excellent advice also applies to the mandolin - as I have been discovering since transitioning from guitar.
    spatzo
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005015 / 1.052658]
