I should say not for a magnetic pickup. Any reason not to use a 10inch.
I do own a Bose S1 which has a smaller speaker. On certain gigs I have limited space but need to play both Gypsy and an arch top. The 10inch is better than a 6 for the archtop so trying to get a way with using one amp.
Conventional wisdom is that a 10" has more oomph than a 6"--but my Blu Six sounds just fine and weighs significantly less than a 10" Bud. If I were twenty years younger, I'd probably gone with a Bud, but those few pounds made enough difference in the logistics department that I'm content with the tradeoff.
I'm sure you know more than me but doesn't it depend on magnetic pickup vs trying to get a good acoustic sound?
I'm really happy with my cheap ass Alto 410X powered PA speaker for either modeling amp stuff or my IR/piezo thing.
Thanks Paul,
www.scoredog.tv
I think 10" will always sound better. The only drawback would be the weight I'd say.
Hi Craig,
I have the 10" Henriksen Bud. Weight shouldn't be an issue, it is as warm as a non tube gets!
I am going to own both for a bit and then probably lose the Bud6 or the S1.
www.scoredog.tv
