Total comittment!
    I am a little curious exactly what they are measuring - a impulse response measures the entire system - so that means the source, the reciever, and the room - If it is something like a preamp it can be done electronically - but a mic the capsule is part of the sound. Don't have the time to look into it - but if someone had a quick answer.
    I am working on an insane IR maker. Still testing things but it potentially will do some crazy things. All inspiration goes to Vic Wong, I'm hoping to push this a lot further. Current bottle neck is not having pedals that will play acoustic IRs at length, that's part of the project.
    This is all open source if you want to check it out. On the demo page you can see the green line which is the recorded piezo compared to the mic signal and how wildly weird it is in the lower frequencies.
    I have about 6 projects going right now and haven't given this enough attention but I'm planning on running some tests tomorrow with a mockup of the pedal to run full length IRs.
    I will have a Super IR thing with additional features which I might sell at some point. The goal is to have a little onboard processor for the IRs so you can plug a guitar straight into a PA speaker and get something approximating a mic'd sound. Proof is in the pudding, I'm not there yet.
    Anyway, it's here. It's cool. TBH I can't believe that I was able to get this working. Absolutely all AI vibe coding but it has been super interesting.
    https://github.com/paulmcevoy75/acoustic-ir-studio
    One thing I think with the IRs is using the flattest ass mic you can, I'm using a room analyzing mic I have for analyzing guitars. Anyway, way off topic....
    the IR measures the difference between a piezo and the mic'd signal of a guitar recorded simultaneously. It compares the two signals and then makes an IR which runs on a pedal from the piezo to an amplifier. The idea is to sort of reverse engineer (not really) the piezo signal to more resemble the mic signal.
    It works pretty well but at the moment all the IR loaders are almost exclusively geared towards amp modeling which seem to get away with a much shorter length IR and need less processing power. I'm working on a version for the Daisy Seed chip which can run much longer IRs which will hopefully take more the piezo crap out of the signal.
    So it is picking up the room as well but maybe it is minimal in the big picture.
    Wait, but it isn't recording an actual dirac impulse (swept sin, mls etc)... so what exactly is the impulse it is using? Is it finding a transfer function then creating the impulse post-hoc?
    I come from the acoustics world so maybe I am not understanding this right.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.041863 / 1.186394]
