Slowing down Django (for Mac only)
    What a great tip, thank you, gama!
    "Audacity" it is!
    (But anyway, mac users, I would still definitely recommend both iMic and Garageband for making home recordings...)
  • seanrayseanray Madison, WI✭✭
    Why not just use Quicktime?
    On a Mac or PC it'll slow down video, audio and also adjust pitch for free.
    Just select "Show A/V Controls" from the Window menu. That's where you'll find the faders.
    Yes, seanray, I do use QuickTime, but the version I have does not allow me to record anything, but play back only...
    So this necessitates the complicated process which I talked about above:
    -first I use GarageBand to copy the Django stuff I want off a CD
    -then I use GarageBand to edit it down into bite-size clips
    -then I "share" the final result to iTunes
    -then I take the finished clips out of iTunes and dump 'em on my desktop where they somehow automatically turn into QuickTime files
    -then I can play around with those QT files, just as you indicated.
    Will
    Sounds good Will but you may want to consider dropping $29 on Quicktime Pro.
    With the pro upgrade you can do everything you're describing, in one app, with a lot less time and hassle. With QT Pro you can edit all you want, set loop points, etc.
    Just a thought.
    Thanks for that info, seanray.
    I'm one cheap SOB, but I'm going to consider spending that $29!
    :mrgreen:
  • gamagama ✭✭
    or don't spend a dime and do it for free on audacity.
    Can you get audacity for PC or only Mac?
    Do you have a link for where to download it?
  • gamagama ✭✭
    "It is available for Mac OS X, Microsoft Windows, GNU/Linux, and other operating systems"
    http://audacity.sourceforge.net/
    and here is the wiki tutorial:
    http://wiki.audacityteam.org/wiki/Audac ... _Home_Page
    Thanks Gama!
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004598 / 1.060158]
