E7 to Am lick
ramsezazramsezaz Paris, FranceNew
edited October 2005 in Technique Posts: 90
Here is a lick I transcribed from moreno "Fils du vent" CD (I don't recall which track) : (see the Welcome forum for the discussion about licks)
[code]
E7 E7 Am
___3____ ____3___
-12-11-12-|-13-12----12-------------|----------------------13h15p13-|-12------------
----------|-------15----13-15-12-13-|-12h13p12-------12-15----------|----13---------
----------|-------------------------|----------14-13----------------|-------14--14--
[/code]
Any comments are welcomed !
my lutherie blog : http://ramsezaz/blogspot.com
    that looks cool, i dont have that cd but the point i want to make is:
    when i show licks (or if they show me licks they transcribed) to my students, i make sure they understand them clearly ...
    in other words, they know how it works rhythmically, (where it should be placed)... in this case, this is a lick that comes before the beat (as fapy would say), that is it anticipates the chord (E7), it's also important to know where it ends rhythmically
    then it's important to be able to visualize the chord position that it's derived from, so you can understand it clearly in harmonic terms and so that u can transposite it elsewhere... in this case;; it's coming from this shape:
    12 14 12 13 15 12 (E7) (that's the shape i like to visualize but any variation from this position will do)
    x 12 14 14 13 12 (Am)
    check out this kickass bireli chord: 0 11 11 11 11 18... play that over Bb7 or E7
  • ramsezazramsezaz Paris, FranceNew
    maybe this should be moved to the licks forum ? :)
    i don't know how :-P
    dis donc, tu fais comment pour que la tab soit bien alignee comme ca?
    quand tu tapes ton message, t'as des balises juste sous le sujet genre "B i u Quote .... et surtout Code qui permet d'utiliser une police a chasse fixe (chaque lettre a la même largeur)
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005713 / 1.060463]
