Help with Dream of You
    DjangoJim wrote:
    Hey Phil-
    One of my faves. This isn't a grill but should do the trick.
    Jim
    Jim -
    Your chart shows Django as the composer, but that song was actually written by Cy Coleman.
    Thanks all for the real Grille! I've got the start of the head down, as per directions from
    Mr. DC...can someone also share the descending chords that come immediately following the opening melody line? cheers, Phil
    They're in DjangoJim's PDF in notation form.
    ....Hi Phil -
    That descending chord voicing you are asking about starts with the middle four strings (Rocky Gresset version) EMaj (7th fret Root E on A string/like open D chord plus the g# note on D string) and holding the E note on the high B string as you descend to a C#dim, then1/2 step down your lower 3 fingers(holding the E note on higher B string, then the open position E chord we all know!
    ......You can also higher octave this progression by using the E Maj triad (3 notes) on the 12 fret (3rd, 5th, tonic E) holding again the high E and descending the other two fingers!
    ......Rocky
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005993 / 1.060539]
