help with words meaning needed
hi guys
I also came across term' strings clearence' in the context of installing krivo pickup. What does ' string clearance mean in this context?
what are ' pole pieces' in the same context?
  • WColsherWColsher PhiladelphiaNew
    String Clearance is the distance between the guitar strings and the top surface of the pickup (or the pole pieces).
    Pole pieces are are the individual cylinders of magnetic material that convert each string's vibration to an electrical signal. In many cases, the height of each pole piece is adjustable so one may adjust the relative loudness or each string.
    If you Google "guitar pickup diagram" some helpful pictures will show up at the top of the results.
  • rafapakrafapak ✭✭
    thanks colsher
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005812 / 1.062889]
