Playing at night
sjlsjl ✭✭
edited May 2012 in FAQ Posts: 31
Hi mates.
I want to practice at night without disturbing my neighbours.
Someone told me that I have to put a sock under the strings and recently I became aware about yamaha's silent guitars, but I don't know if these can be a good gipsy guitar sparring.
Any advice?
Thanks in advance for your help.
  • swing68swing68 Poznan, Poland✭✭✭ Manouche Modele Orchestre, JWC Catania Swing
    Take a thick common-or-garden bathroom sponge, the densest you can find. With a stanley knife, cut a chunk 1 inch wide & about an inch wider than the space between your strings at the bridge.
    Now make 6 5mm-deep cuts into the sponge so that the cuts correspond to each string. Fit it over your strings at the bridge.
    Quite apart from the reduction in volume it makes it much easier to focus on even picking at high speeds.
    In the age of the Orange Man, thank God we got the blues ...
    Or you could play heavy metal CDs full blast, then your guitar playing wouldn't disturb them at all.
    Klaatu, you're a wonderful person, but I'm glad you don't live next door! :mrgreen:
    Will
    Well, you know most of the heavy metal guitarists claim Django as an influence, so there is a connection of sorts.
  • PerltonePerltone ✭✭✭
    I use the foam rubber on banjo and guitar by putting it under the strings touching the bridge, on the soundhole side. No need to cut string slots
  • matty42matty42 tyrone, pa✭✭✭
    Very funny! :D
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006544 / 1.060463]
