Chair
13»
    bopster wrote:
    After 2 torn lumbar discs I needed a good solution for back pain when I play. I use a Medline lumbar support attached to a wooden folding chair I bought at Target, and it works great at gigs.
    Look at yourself in the mirror and make sure the seat is long enough and at the right height (with feet flat on the floor, and your back against the back of the chair, does the front of the seat support your legs or is there a gap? They should be supported by the seat all the way to the crick in your knees).
    Hey Bopster -
    Old thread, just wondering which particular medline support you used? I have a massive tush-cush (hold the comments, please :D ), but my swivel office chair still doesn't cut it, need a support. Do you use one you put on yourself, one that is strapped semi-permanently on the chair, or just one of those arched cushions, you place behind your back?
    -Paul
    pas encore, j'erre toujours.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006846 / 1.053185]
