Audia Technia mics?
    Whats the installation like for the ischell ? Is it fairly simple ? When you buy it, does it come with everything you need to set it up and plug it into a PA, or are there other accessories you must buy ?
    Anthony
    Anthony
    Yes, it comes with everything you need. Double sided adhesive holds the jack to the tailpiece and putty secures the pickup to the top. It's all removable and non-permanent.
    thanks,
    The only mod I did, I got from Jim (Jkaz), a good one - adhesive-backed velcro on the tailpiece, and on the jack. Sticks well, but nothing permanent. I found that the adhesive that is used on the rubber foot of the jack wasn't enough, on my guitar - the jack kept falling loose during our set.
    -Paul
    pas encore, j'erre toujours.
  • MarkAMarkA Vermont✭✭✭ Holo Epiphany, Gibson L-5, Recording King M-4
    I have been very pleased with the Ischell and use it regularly on gigs with a fairly loud quintet (drums, sax, trumpet, and bass). It sounds great on the ALD La Brune I'm using now and it was just as good with the Dupont MDC-50e I used before. I have used it on two Epiphone archtops with excellent results as well. It resists feedback very well, on the few occasions where there was any it's always been that I needed to make the seal between pickup and top a little better (which takes seconds).
    Hey Paul,
    Where do you get the adhesive backed Velcro?
    thx
    Hey Bones -
    I think I just got it as part of an Amazon purchase, but I forget, to be honest. It's really common stuff. I think most fabric stores carry it?
    Edit: Actually, this is the stuff I got, I think. I just cut it to size.
    -Paul
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.010569 Seconds Memory Usage: 1.464569 Megabytes
