What is the best Tablature creation software ?
13»
    Do any of these generate tab from sound? Or do the notes (pitch and length) have to be discerned by the ear and entered manually?
    wim
    I think sybellius does it from sound. Problem is, with guitar how can it possibly know where you're playing any given note ?
    edited July 2014 Posts: 1,643
    good question @Charles Meadows .. I'm an engineer with mathematics background, I have great interests in pitch detection / fourier analysis and have got some some big plans in this area :) I worked for years in image matching and I am 99% certain I can apply the same algorithms and principles to note matching. If only I could quit my day job and dedicate some time to these fleshing out these ideas and seeing if I can make some promising results ..
    Yes Powertab and GuitarPro, Tux....have MIDI playback so one can slow things down, loop, whatnot which is great for practicing as well. Again I recommend PowerTab out of all of them, it takes a few to figure out all it's features but it really covers all the basis. For example for things like position shifting (placing same notes on different frets by highlighting a whole section and pressing a button) l found it the easiest vs Tux or GeetarPro. But the MIDI playback is really benefitial.
    Yes Powertab and GuitarPro, Tux....have MIDI playback so one can slow things down, loop, whatnot which is great for practicing as well. Again I recommend PowerTab out of all of them, it takes a few to figure out all it's features but it really covers all the basis. For example for things like position shifting (placing same notes on different frets by highlighting a whole section and pressing a button) l found it the easiest vs Tux or GeetarPro plus for tabbing, writing etc one only needs a few features that's why PowerTab has not been for years and still is in heavy usage. But the MIDI playback is really benefitial.
  • edited July 2014 Posts: 3,707
    @Charles Meadows and @AmundLauritzen .....Sibelius can interpret midi input, not sound. In order to use it with guitar you need a midi pickup. From the reviews I have read the Fishman Triple Play is the first midi pickup that can be set up to work with Sibelius without a huge number of errors. If you input really cleanly, (fingerstyle?) I gather the dots are accurate and as each string is tracked by a separate magnetic pole it will tab it out for you if desired.
  • Sorry auto correct keeps removing the I from MIDI
  • mandocatmandocat Santa Rosa, CA✭✭✭ AJL XO, Eastman 905CE, PRS SE
    Anthony, the old hotclub.co.uk site has a lot of power tab transcriptions under the Playing tab. You can use some of those to get an idea of how to use the software. A nice feature is the score checker, which you can use as you go along to correct errors.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.010836 / 1.492012]
