Replacing the tailpiece
Hello!
I am wondering if anyone had experience with changing the tailpiece alone. As far as I have noticed there are only a couple of bolts holding the tailpiece. My biggest fear is that when I am gonna replace it the bolts are gonna become loose. I am probably gonna go to a guitar tech to let him do the work but anyway some information cant hurt!
Greetings
  • JehuJehu New Zealand✭✭✭
    I'm all for supporting your local guitar tech, but they're just screws, my man. If you end up with a loose screw, just add a small piece of wood (e.g., flat toothpick) to the hole.
    thorjensenwimNejc
    Are you swapping like for like tailpieces - if not you might find the screwholes don't line up. If they don't then I'd recommend filling the old holes with toothpicks and glue so you're giving the new screw holes a bit of support.
    Nejc
  • NejcNejc Slovenia✭✭ Altamira M01
    The screwholes line up, I checked that. I was just afraid that something would go wrong since I have never done this before. Anyway thank you for your comment!
    Remember that they are just threading into wood so just tighten them up snug. Don't strip out the wood.
  • Mine has been out several times...the key is to not over tighten going in
    Bones wrote: »
    Jazzaferri wrote: »
    Have done it by myself and it worked out great! Thank you for all the info and sorry for the late response!
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004533 / 1.052582]
