schatten or shertler basik ?
  • calòcalò Bilbao, SpainNew
    Michael, one more doubt:basik or the basik pro?, wich one I should by for live gigs?. I play via mixer to the PA, and sometimes with selfpowered monitor
    Most people use the basik set....it has a separate 1/4" phantom power adapter. Most people are plugging into a 1/4" input, the basik set is designed for that.
    The Basik pro has the phantom power built into an XLR adapter....so if you're plugging into a PA or mixer which only has XLR inputs you might want the pro instead.
    If you're using an amp or mixer that provides phantom power you don't need to worry about the extra adapters.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006039 / 1.052368]
