"Vakulabharanam" scale
in Licks and Patterns Posts: 1,889
Anybody every used this Egyptian sounding scale?
C C# E F G G# A# C
Mr. Google tells me that this scale has a name: "Vakulabharanam"
I stumbled upon it playing my banjo, attempting to ape a funny belly-dancing tune.
It sounds kind of vaguely minor, even though it has a major third, but I don't think it can actually be categorized as either major or minor.
Sounds real nice on plectrum banjo because you can play it over droning open C and G strings, and its fun to fool around with.
    edited March 2017 Posts: 3,338
    Hey Will, isn't that the same as F harmonic minor? Yeah it's used a lot in GJ but mostly in the context of C7 it usually becomes just C7b9 arp. Not usually the whole scale but that said there are a lot of examples where the whole scale is used even by Django.
    Aha! Thanks, Mike, you are absolutely correct!
  • edited March 2017 Posts: 3,707
    Its actualy the 5th mode of the Harmonic minor scale and is used in Indian and middle Eastern music a lot. I riff on it most every day on sax to a tanpura
    C Db E F G Ab Bb C are the correct note names. The raised E instead of the usual Eb as would be dicatated by the key signature of 4 flats F minor.
    There is another similar scale using all the same notes excedpt a B instead of a Bb which gives two minor third jumps
    edited March 2017 Posts: 1,636
    A good example is the bridge section in "Django's bolero", that's this same sound - probably even exactly these notes if I'm remembering correctly.
    Jazzaferri wrote: »
    I've heard that one called Hungarian scale. It can works well over the A section of a tune like Caravan. But the sound of this scale maybe a bit limiting, it has too much a strong flavour and so gets tiring on the ears early..
    Wim Glenn wrote: »
    That's pretty much my avenue over Caravan.
    So now I know why audience goes from :) to (: by the time I'm done ;)
    t-bird
    Buco wrote: »
    Heh. Well, it's a tiring tune, so many bars of V7!! I found a nice thing to use on Caravan, you can put sounds from the IVm6 and it works well. So, when the rhythm is on the C7 and moves up to a C#7, you counter down and use some Bb-6 arpeggios. Changing between C7(b9) arpeggios and Bb-6 arpeggios, you can get some nice movement happening so it doesn't sound like too much V.
    You can actually use the sound successfully as the rhythm player too if you pick good voicing, the first inversion keeps the good bass movement going - i.e. just taking the C7 and raise the root and the 3rd a fret, keeping the 5th and 7th in place. Instead of shifting up and down between C7 and C#7(boring!), sometimes I'll use the C
    [8 10 10 9 . .]
    and Bb-6 voicing like
    [9 10 8 10 . .]
    This is cool but I'm little confused with this C shape?
    Buco wrote: »
    yeah...? what's wrong with it? ;)
    "Anniversary Song" has the extended V7 that is perfect for this as well.
  • edited March 2017 Posts: 5,753
    Wim Glenn wrote: »
    Buco wrote: »
    Hah I was way overthinking it, holly cow, it's a vanilla C triad.
    Too much coffee and too little sleep.
    It actually sounds nice in the context of the change to that Bb-6 shape.
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.006203 Seconds Memory Usage: 1.010307 Megabytes
