advice for securing krivo pickup cord
I recently put a single coil krivo on a dupont nomad oval hole. I like the tone but I want to figure out a way to secure the cord in case there is a tug on it during a gig. I do not use a strap. Any suggestions? I was thinking I could hot glue some sort of bracket on to the tailpiece but I suspect there might me a more elegant solution out there?
  • edited May 2019 Posts: 6,142
    Quick and easy would be loop the cable around your leg once, right where the guitar is resting on it.
    Wire it internally to an endpin or cut down the cable, add connector like 1/4" female and velcro to the body somewhere
    Another thing you could do is use is one of these cable holders, remove the adhesive they come with and use the putty you're using for your pickup and you can stick the cable in the back of the guitar.
    I assume you want to avoid ripping the pickup off the guitar...
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004332 / 1.053253]
