BYO D-Hole Dimensions?
whitneyguitarswhitneyguitars New Gitane DG-340 Modele Stephane Wrembel Model
I'm hoping someone can help me out. I purchased the plans from Francois Charles for the oval-hole Selmer guitar and want to build a D-hole model. As I understand it, all is identical to the oval hole with the exception of the bracing (to accommodate the large sound-hole).
To my best guess from looking at photos, the sound-hole itself measures ~70mm high and ~155mm wide.
Could I trouble any of you with a D-hole model to confirm the dimensions as well as the width of the rosette / spacing between the sound-hole and rosette?
Thanks in advance!
Mike
    edited May 2019 Posts: 3,338
    Hi Mike,
    On the Charle plan it is about 155 x 65 mm.
    Edge of D hole to rosette about 4mm. Rosette 15mm.
    Brace 1 is 17 wide x 20 high.
    Brace 2 is 10 wide x 20 high.
    4 braces.
    Let us know how ur build goes. BTW for ease of searching we title luthier posts BYO for build your own. I edited it for you. Hope that's ok.
  • whitneyguitarswhitneyguitars New Gitane DG-340 Modele Stephane Wrembel Model
    edited May 2019 Posts: 22
    Hi Bones -
    Thanks a ton for getting back to me. No problem at all on the edit and thank you for the tip. I'll preface future posts with this.
    I since discovered an illustration in the Francois Charles book as well. It reads as 70mm high by 154mm wide (if I recall correctly - books is at the shop). I also messaged another builder in France and he said that he sets the height of the D-hole to the same as the oval (70mm) and then just scales proportionately which puts him in this range.
    Cheers as well for the additional specs on the rosette / spacing. I'll post some progress pics along the way.
    All the best!
    Mike
    BTW those actual dimensions were not on the drawing so I just scaled them with a metric ruler. It should put you in the ballpark.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.013674 / 2.191261]
