Speaker Recommendation
Hey guys,
I'm a bass player turned gypsy guitarist. I have a great bass amp. I also see guitarists use - an Acoustic Image Focus II R. Can anyne recommend a speaker to use with this for guitar? None of my bassc cabinets sound that good.
Rick
    Get an extended range Reazer's Edge cabinet. Djangobooks sells them. A perfect match with your amp.
    Stringswinger - good Idea.
    Personally I use a (ancient) Coda.
    I'd consider a hat box (Harvie S designed speaker from Acoustic Image). My usual bassist has one and we have run through it together on occasion.
    What might be important to mention here- what kind of pick-up/mic are you using? Playing Rhythm or leads?
    I use only Mics (dpa and rode) and really only play rhythm with this set up (and use an ampeg with my magnetic pickups on archtops).
    B
  • RSpenceRSpence New
    Thanks for the replies. This looks good:
    I need to figure out a pickup as well. I haven't played out much yet - so hasn't been an issue but the two times I did play out with a pickup I used one of these iRig Acoustic stage things and it sounded pretty terrible! I eventually got a decent sound with the Acoustic Image head and a bass cabinet which has an 8, 5 and tweeters but it wasn't that great....I think I'll start with that speaker and assuming the IRig acoustic sounds just as bad I'll then look at some clip on system - I don't want to cut into the wood on this Polak I am using. I want to be able to play both rhythm and lead.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004312 / 1.063103]
